need part # for 37mm poly bushings
Old May 28, 2002 | 09:03 AM
ForzaAzzurri's Avatar
Hi all, I was wondering if anyone had the part number for the 37mm front sway bar bushing so i can order them from summit.
thanks for any info
Old May 28, 2002 | 10:15 AM
vjo90RS8's Avatar
Car: 2002 Z28
i think you mean the 36mm bar, and summit does not sell these, the largest they go is 35mm (energy suspension). If you want poly 36mm bushings that will fix the stock brackets then go to www.guldstrand.com and give them a call, they are 20 a pair.
Old May 28, 2002 | 04:10 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
You can also use the Energy Suspension Universal fit 35mm bushing and bracket -OR- do like I did and use the ES 34mm in the factory bracket.
LT1Formula
20
Nov 14, 2015 12:02 AM
Reddeath210
Oct 6, 2015 08:20 AM
GVMV
Exterior Parts for Sale
Aug 16, 2015 07:08 PM
1nastygta
Aug 8, 2015 07:38 PM
NBrehm
Aug 5, 2015 07:57 PM
