Polyurethane bushings
Old May 30, 2002 | 09:07 AM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
I have an 89 GTA and are looking for info. Are my suspension bushings already polyurethane? I think someone told me as much. If they are I don't really see the need for replacing them, but if they're not I would like to replace them with some. So please any insight would be greatly appreciated.
Old May 30, 2002 | 09:27 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
From the factory we have rubber. Aftermarket companies use either poly or polygraphite.
Inspect all of the bushings. If they are severly deformed and/or are cracking then replace them. Rubber is fine, if you want performnace, go with the ploygraphite but it can sweak a bit.
Old May 30, 2002 | 11:36 AM
Steve89GTA's Avatar
I've got an 89 GTA and I'm in the process of chaning to poly. Best thing you'll do as far as suspension to tighten things up. Keep them lubbed up nicely and you won't have problems with noise.
Old May 30, 2002 | 02:55 PM
Engine: 3.0
thanks guys, I guess I was misinformed about the bushings. What kit(manufacturer) are you installing?
Old May 30, 2002 | 03:22 PM
Omega's Avatar
Engine: LS1 / LS3
www.p-s-t.com
They make the polygraphite parts.. and other toys.
Old May 31, 2002 | 06:01 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Actually, some cars did come from factory with at least some poly (we had this discuss some months back on the History Board, if I recall correctly). My 85 IROC did absolutely come stock with poly end links. Currently, I'm running 1LE sway bars. I purchased the poly end links and higher durometer bushings directly from GM.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
