Wheel size over disc brakes
Old Jun 9, 2002 | 11:34 AM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
Will this wheel fit with a 245-55-16 tire on the rear of my Iroc with disc brakes?
Specifications:
* Diameter: 16 in.
* Width: 8 in.
* Bolt circle: 5 x 4 1/2 in. and 5 x 4 3/4 in. dual-drilled
* Backspacing: 4 5/8 in.
* Load rating: 8,000 lb. GVW
* Maximum tire diameter: 31 in.
I don't even know what bolt circle we have. (I come from a VW world, there's 2 types, 5 bolt and 4 lug.) Thanks for any help.
Old Jun 10, 2002 | 02:00 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
ttt
Old Jun 10, 2002 | 06:20 PM
mystikkal_69's Avatar
Car: 1988 IROC-Z
Engine: L98 (350 TPI)
Transmission: MD8 (700 R4) + 3.42 LS1 Rear
the tire should fit fine on that rim. as for the rim fitting on the ROC, i'm not to sure. i don't know all the specs on backspacing and "bolt circle" sizes. i'd figure this would bump you back up top.
you can check that place out for backspacing info.
Skulte Performance Tech Section
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
