I just installed.....
Old Jun 17, 2002 | 10:40 AM
86IROCZ's Avatar
This weekend I put in my Spohn SFC's (which I've had since Feb), Edelbrock Strut tower brace and Eibach Springs.
It feels like a differnt car now, and almost all the squeeks and rattles come from the doors. I still have some unknown creaking sound that comes from the front passenger sided when I stop.
The pro kit springs made my car 1 inch lower front and rear. Keep in mind I was replacing 16 year old springs with 200K on them.
The strut tower brace fit nicely with no clearance problems (TPI), It does come really close to the hood though, it touches the heat shield in two spots.
Old Jun 17, 2002 | 11:13 AM
chevyguy1969's Avatar
Car: 1999 Camaro Z28
Engine: LS1 V8
Transmission: T-56 6spd
Good Job Man! I want to get that same STB but my funds do not allow for it yet. Your creaking on the pass. side is likely coming from a bad ball joint. Did you replace them when did everything?
Old Jun 18, 2002 | 12:31 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
Transmission: Pro-Built Automatic/Vigilante 2800
I noticed the same creaking sound coming from the passenger side also, right after I installed my Spohn SFC. The only difference is I hear mine when I accelerate. And yes my ball joints were replaced prior to installing the SFC's.
Old Jun 18, 2002 | 03:35 PM
86IROCZ's Avatar
yeah, I replaced the ball joints and bushings about a year ago. I think it may be either my struts, upper bearing, or those triangle braces that connect to the frame. I'll check this weekend.
Old Jun 18, 2002 | 04:32 PM
grafx's Avatar
Car: 91 Camaro RS
Engine: 305 TBI
I doubt it's the triangle braces you refered to. Post your results and let me know if you find anything out.
Old Jun 18, 2002 | 04:43 PM
JMatlock88's Avatar
Car: 1991 Formula
Engine: 355 DFI Superram w/ R-Trim
Transmission: Probuilt 700r4
I had a creak coming from my passenger area after I installed my South Side Machien SFCs. It ended up being the SLP y-pipe rubbing on the front of the passenger SFC. You might check exhaust... Just trying to help!
