Return spring part number
Old Jun 24, 2002 | 04:43 PM
urbman's Avatar
Anybody have a part number for the parking brake
return spring...
Old Jun 25, 2002 | 02:05 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Do you mean the big round one or the small one about 1" long with the hook on it?
I had to get the little one with the hook on it that goes thru the caliper, and they ran me $5 each (got 2). P/N 10112650 IIRC.
Which one do you need?
Lemme know.
Ed
Old Jun 25, 2002 | 05:16 PM
urbman's Avatar
Thanks ed
I need the little parking brake return spring
(little one with the loop)
jeez i need to pay attention
By the way if your still doing stuff with the
step by step front end rebuild I have a couple of
shots that might be useful...
1. Shot showing the inside of the spring seated in the
perch
2. Center link adjustment (pivots vs flat spot)
3. Spring centered on drain holes
4. Caliper/spindle clearance check and lube points
If not I'll just keep em for ref...
Thanks again
Al
Old Jun 25, 2002 | 09:10 PM
ebmiller88's Avatar
Yup, P/N 10112650. I remembered.
Sure, send those shots over, I'll put them in there. I have about 30 shots of the rearend install to add!
Thanks!!
ebmiller88@aol.com
1992 Trans Am
May 10, 2023 07:19 PM
355sbcTPI
Aug 19, 2015 04:38 PM
IrocZ'85
Aug 17, 2015 06:24 PM
TA8487
Aug 16, 2015 12:21 PM
armybyrd
Aug 10, 2015 09:23 PM
