Rear disc pad install Q...
Old Jul 11, 2002 | 08:28 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I just installed my new EBC pads in my PBR rear calipers. When I took the old ones out, they had H-shaped shims glued to the pad between the pad and the piston actuator assembly. My new pads did not come with any shims. Do I need these?
Also, do I really need to do the adjustment that "zeroes" the pads? This is done by adjusting a very small allen screw located opposite the e-brake plunger rod, if you understand what I'm getting at then you know what I'm talking about.
Any help appreciated.
Ed, getting oh soo close...
Old Jul 12, 2002 | 06:30 AM
ebmiller88's Avatar
TTT....
Oh come on....
Old Jul 12, 2002 | 07:18 PM
Eightyninef's Avatar
please explain that thing about zeroing the rear calipers. I have the PBR rear's and I just replace pads with out doing anything else.
and about the shims. that is just to stop squeaking. they seperate from the pads when you beat on the brakes badly, they they don't come out with the pads.
Old Jul 13, 2002 | 06:07 AM
ebmiller88's Avatar
I'll get the instructions from the rebuild kit and copy what they say. It sounds like a pain in the ****, but they say it "must" be done. I don't think half the people out there even try, but I had to ask.
As for the shims, that's all I needed to hear.
Thanks!!
Ed, anxious to pack bearings..(?)
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
kyleb24
Aug 15, 2015 08:24 AM
