1.7-1.8 60' ft's?
Old Jul 17, 2002 | 07:01 PM
e-man's Avatar
Car: 89 formula
Engine: 383
1.7-1.8 60' ft's?
Can I pull less than a 1.9 without a adj. torque arm or sub-frame connectors?Im using BF drags and can get 1.9s sometimes mostly 2.0s will it be easier with the subs and torque arm?
Old Jul 17, 2002 | 10:04 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i put the lakewood adjustable panhard rod and trailing arms in my car. best on 225/60-15 raidal tires (not drag radials) is 1.964 now if i add some drag radials i'm sure it'll be in the 1.8's
Old Jul 18, 2002 | 04:13 AM
e-man's Avatar
Car: 89 formula
Engine: 383
I have lakewood LCA's but I didnt do the panhard rod its more for cornering than drag racing right? Which one would help more the frame connectors or torque arm? Im going to get both sooner or later.
Old Jul 18, 2002 | 07:18 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
The one single thing you can do to the suspension that will lower your 60' the most, is LCA lowering brackets. The difference is astounding. They correct the stupidly wrong geometry in the design of these cars whereby the rear of the LCA is higher than the front. What that does is make the rear end want to lift itself off the pavement more and more the more it tries to push the car forward. Lowering brackets lower the rear of the LCA, such that when the rear end tries to push forward on the car, it tries to push itself down into the pavement.
You will break strange things if you get better 60' times than 1.9 without SFCs, like windshields. Definitely get a set of those. If you want to know why, have somebody videotape a launch from the left side of the strip about 50' down the track looking along the side of the car with the camers about a foot off the ground, and play it back in slow motion. You'll probably be able to see the car bend upward about ¾" in the middle a couple of frames after power is applied and before the left front corner of the car starts to lift.
Old Jul 18, 2002 | 03:35 PM
e-man's Avatar
Car: 89 formula
Engine: 383
I have BMR LCA relocation brackets allready so get the subs first than the torque arm?
Old Jul 18, 2002 | 10:22 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Suspension alone won't lower your 60' times. It all has to do with torque. If the engine doesn't produce enough and the torque converter stall speed is too low then there won't be enough torque to lower the 60' times. Tire size and gearing also plays into 60' time.
All an aftermarket torque arm and SFC will do is reduce or eliminate chassis and suspension flex to make the 60' times more consistant.
Old Jul 19, 2002 | 04:02 AM
e-man's Avatar
Car: 89 formula
Engine: 383
OK I get it now Thanks.
Rexer
Aug 16, 2004 04:49 PM
redtail2624
May 17, 2003 10:20 PM
