how to switch to rear discs??
Old Jul 27, 2002 | 05:42 PM
Nasty_Bird_'90's Avatar
i just got my hands on a 9 bolt rear with disc brakes. my question is what will i need to change to use the discs? proportioning valve, lines? thanx
Old Jul 28, 2002 | 05:33 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Do you plan on installing the LE front brake package any time soon? If so you might want to do the swap at that time. Then you could use the 1LE prop valve and save some expense by only needing one valve.
Thanx,ANDYZ28
Old Jul 28, 2002 | 06:46 AM
Z28DJP1987's Avatar
All you will need in additional parts are the Proportioning Valve and the Parking Brake Cables for a BW 9-bolt. Otherwise its a straight forward swap. I hope you have the 89 9-bolt, because that was the year for the 11.655 rotors the Alum, PBR calipers.
Good luck.
Old Jul 28, 2002 | 10:19 AM
i dont think its a BW and im not sure of the year. im getting it from a buddy of mine soon. i dont plan on doing the 1LE. the only reason im doing this one is because it kinda fell into my lap.
whats the best way to get the prop. valve that i will need? should i get an OE replacement from an auto pars store or is it an OK junkyard part? thanx guys.
Old Jul 28, 2002 | 11:35 AM
Z28DJP1987's Avatar
Nasty_
Best to wait and identifly the rear you are getting then think about what parts you will need. My opinion.
Old Jul 28, 2002 | 02:24 PM
That's what i figured. I'm just waiting on an e-mail from the guy now. thanx. I'll keep you posted.
Old Jul 28, 2002 | 02:35 PM
It turns out that it is an '88 BW 9 bolt 3.27 posi disc rear. Now that we've got that straight, what will i need? thanx a bunch
Old Jul 28, 2002 | 03:06 PM
Z28DJP1987's Avatar
Nasty_
Just the parts I quoted before. But check the brakes out, rotors,pads and calipers. I can not say the early BW had the same disc problems as the 10-bolt brakes. Someone else may have a answer for this.
Old Jul 28, 2002 | 07:03 PM
What are these problems??
Old Jul 29, 2002 | 09:52 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Rear calipers tend to not adjust right which in turn doesn't allow them to fully engage the rotor which = crappy rear brakes. You can rebuild the rear calipers with a recall kit and it will take care of the problem. I just said the hell with it and found an '89 rearend, and also went to 1LEs....WAHOO!!
Ed
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
