Help removing lower shock nut...
Old Aug 3, 2002 | 07:31 PM
scanman717's Avatar
Car: 92 Z/28 Convertible
Engine: LB9
Transmission: Mad Dog Auto 700R4
I put in some KYB Shocks a few weeks ago and decided to change the springs this weekend... The problem is that on the passenger side the lower shock bolt (the one that attaches to the axle) just spins on the bolt, it does not move..
I tried to wedge it so that it might catch and turn, no luck. None of the liquid stuff helps either. Went and got a nut cracker, but it won't fit into the area where the nut is...
Any other ideas on how to get it out???
Troy
Old Aug 4, 2002 | 01:08 PM
craig's Avatar
Car: 86 camaro
Engine: 433 big block
Transmission: jw powerglide 5500 coan stall
Axle/Gears: moser9" 4:11 posi
heat always helps.ithink you might be able to get on the other side with channel locks
Old Aug 4, 2002 | 03:50 PM
scanman717's Avatar
Engine: LB9
I LOVE MY DREMEL...
Finally got it off today... Took a while and several heavy duty cut-off wheels (couldn't find any of the fiberglass ones). But I got it..
Turns out the Bolt threads were gone, the bolt was almost smooth.. Guess I got the nut on a little tight....
Now if I can just figure out why the car is still leaning........
customblackbird
Aug 15, 2021 10:16 PM
deracer
Apr 11, 2016 12:04 AM
LT1Formula
Nov 16, 2015 01:13 PM
kevyb1973
Aug 24, 2015 04:11 PM
3rdgenparts
Aug 8, 2015 07:09 PM
