Old Aug 9, 2002 | 06:52 PM
Camero90tbiRS's Avatar
Will any brake booster from 82-92 camaros/firebird work on my 90 camaro? Im getting one from a junk yard and need to know if any year thirdgen will work. Also will the proportioning valve be the same?
Old Aug 9, 2002 | 08:03 PM
ede's Avatar
ede
i believe the boosters are the same, the PVs are either round and cast looking for disk/drum or flat machined for disk/drum or disk/disk if you never changed anything keeo you PV and just change boosters
Old Aug 9, 2002 | 08:07 PM
I know ive posted this problem before but heres my new problem. i replaced the pads, master cylinder and the calipers/rotores and all lines are in good shape. The only thing not replaced is the booster. Everyone i know says that if the booster goes out it will be hard to push down. The pedal still goes to the ground and doesnt stop the car. Can the booster be bad? I cant see anything else it could be.
Old Aug 9, 2002 | 10:10 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
The combination (proportioning) valve is different for '90-'92. The thread size and pitch is different.
Thanx,ANDYZ28
Old Aug 10, 2002 | 03:25 AM
Thanks alot. How much does the proportioning valve usually cost at a store like autozone?
Old Aug 10, 2002 | 04:49 AM
ANDYZ28's Avatar
Car: 1982 Z-28
You can only get them new from GM. Or AC Delco.
Thanx,ANDYZ28
Old Aug 10, 2002 | 02:27 PM
thanks for the responses
