Chassis set up Primer
Old Aug 11, 2002 | 12:49 PM
Ratchet's Avatar
Does any one know of a chasis set up primer on line or can someone post the basics of setting up a chassis for drag racing.
maybe something like this:
List of what to do to make your f-body launch of the line
1. install posi
2. adjust pinion angle to X degrees up or down??? by doing this
3. install relocation brackets for lower trailing arms an position lower trailing arms a x degrees from horizontal.
4. install air spring in drivers side coil and adjust to X
etc. etc.
It would be nice if the list was in order of biggest bang for the buck, least to most expensive mods, or best traction increase to least etc.
BTW I don't know what works and doesn't work so ignore the list I created just an example of what I am trying to find.
Thanks.
Vintageracer
Jan 10, 2020 05:33 PM
Scamo-2.8
Dec 5, 2015 09:16 PM
zayne0
Aug 24, 2015 07:22 PM
LittleFranks
Aug 20, 2015 03:55 PM
Kaweh
Aug 19, 2015 07:06 PM
