Rear end noise?
Old Aug 17, 2002 | 04:53 PM
RadarRunner's Avatar
Car: 1987 Z28
Engine: LG-4 305
Transmission: 5-speed
Rear end noise?
I've noticed a weird thunk/thump in the rear of the car, sounds mostly on the right side, since I swapped out the rear (drum to disc), & have checked out the spare tire etc but no change.
Any ideas?
Old Aug 17, 2002 | 05:26 PM
Anth's Iroc's Avatar
Car: 87 IROC-Z
Engine: =350 sbc
Transmission: TH350
DID you check the diff fluid if its low it will thunk.Try redoning that and if its posi make sure you add the posi additive
Old Aug 18, 2002 | 11:07 PM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
check the calapers themselves
they may be moving when you go over a bump or ruff road
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
BlackBoulder
Aug 11, 2015 11:15 PM
