Subframe Connectors
Old Aug 26, 2002 | 12:49 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
Subframe Connectors
Which subframe connectors are the best? I did a search and people are saying that the alston racing bolt-in sfcs are pretty nice. I'm thinking of getting these and bolting and welding them in. What do you think?
Leigh
Old Aug 26, 2002 | 01:15 PM
lifesun's Avatar
I used South Side Machine, they were only $165.00 from Summit Racing, and they welded on with out a problem. I did alot of research before I chose these, for fear of modifying the floor pan, ect., these were recommended by a great percentage, and I was very happy with them, no modification needed. I did, however, have to enlongate the LCA bolt hole on each connector by a small bit, no big deal, I hope this helps.
Old Aug 26, 2002 | 04:01 PM
ede's Avatar
ede
mine are as far as i'm concerned. since you can't get a set of them i'd look at spohn then SSM
Old Aug 26, 2002 | 04:27 PM
kevosiroc's Avatar
I have installed two sets of Alston Racing SFC's and have not had any problems yet except I could only get one bolt into the front of one side, this was OK however because I welded them on anyway. I never had to modify the floor plan.
Old Aug 26, 2002 | 07:35 PM
ME Leigh's Avatar
Car: 82 Z28
Transmission: TH350
Check out these SFCS, what do you think?
http://www.swracecars.com/f-body.html
Old Aug 26, 2002 | 09:52 PM
Matt87GTA's Avatar
Car: 1987 Trans Am GTA
Engine: Miniram'd 383, 24X LS1 PCM
Transmission: TH700R4, 4200 stall
Axle/Gears: 9", 4.33:1
I just finished having a GP on those SFCs along with everything else that S&W makes for our cars and I got one response from somebody the day after I closed the GP...... We could have gotten some smoken deals through them but instead my buddy and I were the only ones that got in on the deal .
Mine should be here by the end of the week so I can let you know what the craftsmanship and fit is like (I have no doubt that it will be top notch by the way).
91 SrS
Oct 7, 2015 04:32 PM
TMZIrocZ350
Oct 7, 2015 12:09 PM
meeklay812
Oct 1, 2015 03:46 PM
tmork454
Sep 29, 2015 06:33 PM
Gordonr1973
Sep 29, 2015 11:59 AM
