Will 15s fit on the rear of a GTA with disc breaks?
Old Sep 7, 2002 | 12:19 AM
trigger GTA's Avatar
Car: 92 TA vert
ok before people jump all over me about useing 15s its for a set of slicks.
will 15s clear the breaks?
Old Sep 7, 2002 | 12:33 AM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Well back when I had rear disk breaks (borg warner rear) and I tried to put 15" rims it would hit the caliper. So in taht case your gonna need a spacer. You only need those small ones that are like 1/4" thick and then its all good.
Old Sep 7, 2002 | 01:26 AM
RoadRacer's Avatar
I don't have any problems with mine at all.
Old Sep 7, 2002 | 04:54 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
15" wheels should clear with no problem. But you will need to test fit any non-OE wheel.
Thanx,ANDYZ28
Old Sep 7, 2002 | 04:52 PM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
15" factory 3rd gen. wheels will fit. I've used them with drag radials at the local drag strip.
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
sailtexas186548
Jan 19, 2016 12:21 PM
gta90
Sep 15, 2015 04:00 PM
