Tires hitting...
Old Oct 4, 2002 | 11:10 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Tires hitting...
hey there peoples.. k i have 15x10s wiht 275 60's on em n when i go around turns they hit the corner lip of the wheel wells at the top.. the car was origionally a six banger auto but now has a 350 with a th350 behind it.. im thinking it might still have v6 springs but im not sure.. are the tire/rim's just too big for the car or is it just ****ty springs? also the car has excessive wheel hop if you attempt a burnout and bottoms out on everything.... would replacing the springs with stock z28 springs solve this problem? any suggestion would be appreciated.. thanks!
Old Oct 5, 2002 | 03:33 PM
pskel350's Avatar
you can still use the 15x10" rims, but you must go down to a 55 series tire. also installing Z-28 springs will help too.
Old Oct 5, 2002 | 08:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Installing any stock springs out of one of these cars is a mistake. They are all over 10 years old now, and are worn out.
Go get a set of new rear springs. Use Moog CC635. They cost less than $75 and take less then 20 minutes to put in, in the driveway with hand tools.
Old Oct 5, 2002 | 10:25 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
What exactly are the Moog CC635's? Are they Z-28 replacement springs....are they lower?
As far your wheel hop, try Spohn relocation brackets and some new LCA's.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
mattcanty
Oct 12, 2015 11:08 AM
