how do u tell v6 and v8 springs apart?
Old Oct 4, 2002 | 05:23 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
well how? hehe
Old Oct 4, 2002 | 06:04 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Look at the car they came out of?
Doesn't matter, they're all worn out after all these years.
Old Oct 4, 2002 | 06:34 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Although the spring rates are probably all worn out the only way to "kinda" tell is by measuring the thickness of the wire. Thin wire will have a lower spring rate for a lighter car. Thicker wire will have a higher spring rate for a heavier car or for stiffer suspension such as IROC or WS6 suspension.
It's not so much V6 or V8 springs but how much the spring rate is. I use front springs from a V6 car in my race car. Since I have so much weight removed from the front end, the car still sits high.
What you need to do is drive the car onto a scale. Drive the front wheels on to about the middle. That will give you a weight on the front. With only the rear wheels on the scale will give the rear. Add the 2 together and it will equal the total. Once you know the front weight you can get springs matched for that weight.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
