Was there a Posi Unit for 3 series carriers in 84'?
Old Oct 8, 2002 | 05:19 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
What cars and gear ratios came in POSI for the 82-84 model years??? I want a stock unit, for a 3 series carrier.
Old Oct 8, 2002 | 05:43 PM
chacane67's Avatar
Well I know an '84 Z28 did, and it basically had in it what you would call todays Auburn cone type.
Old Oct 8, 2002 | 06:43 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Yes.
The L69 cars had 3.73 gears, and some had the optional posi.
That said: You'll have alot easier time coming up with a SLP late-model posi and a 6-cylinder rear end to get late-model axles out of, and it will be a better setup to boot.
Old Oct 8, 2002 | 09:25 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Her's what I did to....
My RS. I put some Richmond 3.23's in it, upgrading from the stock 2.73 ratio. Then I got a Posi unit out of a 305 TPI auto car for 50 bucks and stuck it in there.
What would be the easiest way to go. I have 3.73's and I want to keep the gears but get some posi going on. I just bought some new rubber so I don't want to fry one tire.
Can I get the same new model unit, grab some axles from a newer model unit from pick a part and put them into my housing? Will they fit? I thought that beside the spline # being different, the ring gear was also a different size.
I am definately not swapping housings, I have rear discs.
I hope I don't sound dumb or anything but I just can't spit out the spline # diff. and ring gear sizes, I can't remember. I install all this stuff myself.
dbrochard
Jan 28, 2016 08:42 AM
georgiaslim45
Sep 9, 2015 08:12 PM
georgiaslim45
Sep 9, 2015 08:11 PM
toyotekk
Sep 7, 2015 06:36 PM
toyotekk
Sep 6, 2015 02:21 PM
