Rear Caliper question
Old Oct 13, 2002 | 03:17 PM
RED92BIRD305's Avatar
Car: 92 firebird and 95 trans am
Engine: LO3 and LT1
Transmission: 700R4-4l60E
Alright cars is all driving fine. But iv noticed this morning when i went out to the car that the back passenger tire had fluid around it. Long story short brake fluid leak. Im low on fluid now, and upon inspection, where the hose screws into the caliper is leaking so my question is, caliper bad or just the brake hose line? What the general conseus for everyone, change caliper or just hose. Thanks for the information people i apprciate it. Ill check back with you all soon.
Old Oct 13, 2002 | 04:05 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Drum or disc?
If they're drum it doesn't have calipers, it has wheel cylinders. New ones are about $12-15. No reason not to replace them whenever you're there anyway.
The leak is probably the line.
Whatever you do to one side, do the same to the other side.
Old Oct 13, 2002 | 04:41 PM
Engine: LO3 and LT1
DISC
its disc thats why im asking if i change the caliper or just the line. If ones easier to do then the other for the price difference. new Caliper is 39.99 hose is 19.99. Iv changed calipers on other cars i know how to do it, im just curious if the caliper is bad causing the leak or if the hose is bad causing the leak and if not truely sure should i just change both? the caliper comes with the hose thats why im asking. thnaks for the help guys.
1985 Trans Am
305TPI
WS6 Suspension
Old Oct 13, 2002 | 06:18 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Well if a caliper and hose is $40 and a hose alone is $20, then a caliper is really only $20 also, isn't it?
For that little money, again, just replace it. Beats worrying about it, or buying the hose and then having the bleeder screw break off when you go to bleed it and then have to buy the caliper and another hose you then can't use... that would be my kind of luck.
Old Oct 13, 2002 | 10:24 PM
Firebird90V6's Avatar
Sad But True
Yeah you have a point there. Just replace the caliper not if it really needs it but for peice of mind.
Old Oct 14, 2002 | 09:03 AM
TravisZ28MAXX's Avatar
Car: 1992 Z28 and 1988 IROC-Z
Engine: both L98s one with SD and one with MAF
Transmission: both 700R4s
Caliper Price
Where are you getting rear calipers for $40 I have a 92 camaro with rear disc and the lowest price I can find is $70 a piece on top of that the rotors are $60 a piece thats from discount auto parts!
Anyways I need a complete rear brake overhaul anyhow.
Old Oct 14, 2002 | 06:33 PM
Autozone
the part is from autozone.
Eric-86sc
Apr 3, 2016 03:52 PM
sailtexas186548
Jan 19, 2016 12:21 PM
25thannivZ28
Aftermarket Product Review
Jan 2, 2016 05:41 PM
redmaroz
Aug 16, 2015 11:40 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
