Weld in LCA relocators....
Old Oct 15, 2002 | 04:37 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
anyone have any pics of their install? Also how easy is it to weld in? I mean I have a welder and all but like do you have to position the bracket just right and hold it there as you weld. Or does it slip on and just need welding up. ****...how to explain....is there a chance for error in accounts of placement. Or is it pretty much fool proof. Thanks.
Old Oct 15, 2002 | 04:55 PM
CrazyHawaiian's Avatar
Car: too many ...
Well if nobody posts a pic, BMR makes bolt in ones. You could buy those and then weld them in after you bolt them. Or if you get the straight up weld in pieces and someone posts a pic, gimme a call and I can hold them while you weld? hehe
Old Oct 15, 2002 | 05:01 PM
JPrevost's Avatar
Car: 91 Red Sled
The key is to install them one at a time with everything hooked up and on a roll on lift. Do NOT install them on a frame lift. Unbolt one of the LCAs and install bracket making sure the LCA aligns up with both of the new holes, tack weld and make sure it's good then weld everything.
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
LC2 TECH
Oct 13, 2015 11:53 PM
91 SrS
Oct 7, 2015 04:32 PM
meeklay812
Oct 1, 2015 03:46 PM
