Steering????
Old Oct 18, 2002 | 06:50 PM
john5.7 87Iroc's Avatar
Car: An '87 Italian Retard Out Cruisin'
Engine: LS1 install in progress
Transmission: 4L60e
Axle/Gears: 9 bolt
Steering????
The rubber boot, in the red circle, on my steeing shaft has a huge split in it, cant see it in the picture its underneith. Its as big as the red shaded area. Is this a big deal? Should I be worried and replace it?
Old Oct 19, 2002 | 08:44 AM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Not really... they often do that.
There's a universal joint sort of thing up in there though, looks alot like a mini FWD CV joint, make sure it stays well greased and reasonably clean.
Old Oct 19, 2002 | 02:43 PM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
On my car that joint has a lot of play in it, you can move the shaft up and down quite a bit. Do they make a replacement?
Old Oct 19, 2002 | 05:07 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
IIRC when you buy the "lower shaft" you get everything between that one bolt just above it, and the gear box.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
loud91rs
Oct 5, 2015 10:05 PM
sjorgens
Oct 1, 2015 07:54 PM
Night rider327
Sep 25, 2015 04:19 AM
