91Z28 Swaybar sizes and questions
Old Nov 6, 2002 | 10:40 PM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
I have a 91 Z28, non1le, 305, automatic car,and disk/drums. What size sway bars do I have? I am seeing 36,24 alot. I also got a rear out of a 97z28 that I am putting in tommorow actually will that sway bar bolt into a 82-92 f-car?
Old Nov 7, 2002 | 08:04 AM
ede's Avatar
ede
why don't you get under the car and look, that way you'll know for sure what you have.
Old Nov 7, 2002 | 10:00 AM
MdFormula350's Avatar
better safe than sorry and find out what you have buy measuring them!
use a mircometer... the size needs to be in mili meters...
Old Nov 7, 2002 | 10:07 AM
ede's Avatar
ede
if you have the right size a open end wrench makes a good gage to check them with
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Measuring is the best way...1"=25.4mm
However, if you can get your suspension code from your car, check here to see if they are listed:
https://www.thirdgen.org/techbb2/sho...ight=Questions
BTW...NICE car. It would match my truck, my Iroc, and my wife's Honda...nothin like a color coordinated garage!!
Ed
Old Nov 7, 2002 | 03:10 PM
Marc 85Z28's Avatar
Yes, 3rd gen and 4th gen sway bars are interchangable.
Old Nov 7, 2002 | 03:44 PM
ebmiller88's Avatar
Only the rear bars interchange, not the fronts.
Ed
Old Nov 8, 2002 | 08:40 AM
91dubZ28's Avatar
Car: 1991 Z28
Transmission: WCT-5
Thanks alot guys.. you all helped out a lot...
toronto formula
Nov 10, 2015 06:17 AM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
knight72
Aug 10, 2015 09:32 PM
