4th gen booster / master with 1LE's ? ( HMS mount guys inside also )
Old Nov 8, 2002 | 04:51 PM
Z28ricer's Avatar
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
Anyone see using a 4th gen booster and master with the front 1LE and 11.65 rear brakes along with a wilwood prop valve as not such a good idea compared to using a regular 3rd gen setup, i've got one and the bolts all line up etc, and the resivoir is more narrow than the 3rd gen one allowing more clearance for those of us with HMS strut mounts along with having a screw on cap eliminating that annoying snap on thing.
Old Nov 12, 2002 | 06:51 PM
mult68's Avatar
Car: 1992 Chevy Camaro RS
Engine: 305 TBI
ttt....interesting topic
Old Nov 14, 2002 | 09:48 PM
Colt's Avatar
Car: '89 Formula
Engine: 383 Megasquirt
Axle/Gears: 7.625
Yes, this is a very good topic. I've been thinking of doing the same thing myself. The mounting holes will be the same like you mentioned. The only thing to take into consideration is size of the master cylinder bore.
"If the master cylinder bore size is decreased and the pedal ratio and push on the pedal remain the same, the fluid pressure (PSI) and the stroke will both increase"
Frozer!!!
Jan 19, 2024 04:55 PM
redmaroz
Aug 16, 2015 11:40 PM
Street Lethal
Aug 14, 2015 08:25 PM
MustangEater82
Brakes
Aug 11, 2015 07:52 AM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
