Camaro weight numbers?
Old Jan 22, 2003 | 06:26 PM
Makaveli's Avatar
how many pounds are thirdgen cars? i have an 86 sport coupe, no ground effects, stripped down thing lol does have ac/heat though, how much do cars similar weigh without the driver?
i have a V6 car, but im more interested in V8's weights, (after i swap for a V8, just wonderin for 1/4 mile references lol) any V8 car's weights? any dam threads that post a few cars and info with weighing in info? lol im mostly interested in V8 sc's... w/out a/c, no crazy stereos that add a few hundred pounds, just a stock car. , or anything close, ill stop talkin/typin now, bad habbit
thanks!
Old Jan 22, 2003 | 06:39 PM
ontogenesis's Avatar
Car: 1985 Camaro, 2015 Audi A4
Engine: V8
high 2900-low 3000
Old Jan 22, 2003 | 07:12 PM
Makaveli's Avatar
seeing the times 4th gen LT1s run and they run 14s stock , and weigh 3600 pounds and such, does that mean stock motor in a 3rd gen is definately lower times? how much lower can i expect?
Old Jan 22, 2003 | 07:48 PM
94-6spd's Avatar
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
Thirdgens are about 3400 lbs. I think.
Old Jan 22, 2003 | 10:12 PM
87daddyformula's Avatar
Car: Formula
Engine: 5.0L
Transmission: 700R-4
I have heard many people claim around 3550lbs but have not gotten the chance to weigh mine. Can't reliably say.
Old Jan 23, 2003 | 05:24 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
Yes, they are all in the 3400-3600 pound range.
Old Jan 23, 2003 | 07:43 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
mine was almost 3800, but that is full power options, AC , a full tank of gas and myself.
i hear the GTA's with all the options weight even more.
Old Jan 23, 2003 | 12:27 PM
Randy92Z's Avatar
Car: 92 Z28 convertible
Engine: Miniram 383
Axle/Gears: 4.10 stk 10 bolt
My convertible was 3520 lbs W/O driver, see my mods below.
Old Jan 23, 2003 | 04:09 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
I think camaros weight like 3,350lbs. Thats what I was told by a few people. And also it says that on my registration O_o
Old Jan 23, 2003 | 04:45 PM
Makaveli's Avatar
anyone know how many pounds are able to be shed from various things at the racetrack, like no spare tire, jack, rear/passenger seats? prolly not too much eh?
thanks a lot for the numbers though people, just what i needed
Old Jan 24, 2003 | 12:17 AM
REVLIMIT's Avatar
Engine: Built L98
Well...I stripped my interior awhile back. And for the hell of it i checked to see how much they all weighed. Heres what I found...
Rear seat - 30lbs
Rear carpet - 20lbs
Front carpet - 30lbs
I havent tried weighing the seat...but I would say....15lbs or so
Old Jan 24, 2003 | 09:04 AM
Makaveli's Avatar
thanks for those numbers, pretty cool info
isnt the rule of thumb for every 100 pounds less is 1 tenth in the quarter or somehting like that?
Old Jan 24, 2003 | 09:35 AM
MRZ28HO's Avatar
Car: was: 1984 Camaro Z28
Engine: was: L69
Transmission: was: 700-R4
From my experience, early 3rd gen Camaros are the lightest. For example, my 1984 Z28 (A4, hardtop, 305 carb, drum rear) weighed 3350 with me in it. I weigh roughly 195lbs.
Old Jan 24, 2003 | 12:02 PM
REVLIMIT's Avatar
Engine: Built L98
Yea from what I know its every 100lbs is about 1/10 off your e/t. But in other tests Ive seen even only 60lbs shave off a 1/10.
Old Jan 24, 2003 | 12:12 PM
Dewey316's Avatar
Car: 1990 Camaro RS
it probably really depends on how much HP you have to start with and your starting ET on how much that weight will help.
Old Jan 24, 2003 | 12:56 PM
Makaveli's Avatar
oh yea... that makes some sense
im dumb lol does a lighter you make the car mean the more traction issues you have with racing and high power cars?
Old Jan 24, 2003 | 01:06 PM
Dewey316's Avatar
Car: 1990 Camaro RS
no what i was getting at (i may be completely wrong here, mind you)
is that in a 3000lbs car that runs 5 flat, 100 lbs may not net him .1 of a second.
but at the same time, on a 2000lbs car, that runs 17. 100lbs may net him more than a .1 of second.
Old Jan 27, 2003 | 10:43 AM
wyclefsirocz's Avatar
Car: 1989 Iroc z hardtop
Engine: peanut LB9
Transmission: slopomatic TH700R4
3491lbs with me in my 89 iroc(i'm 170lbs)
thatz with a sub +amp setup that weighs about 40lbs
some dyna mat here and there along with a couple of other things like the (under body neons, i removed them, and the spare,jack,sub nd amp
now with me in the car it wieghs 3417 w/ me in it
Old Jan 27, 2003 | 09:39 PM
IROC-Z4ever's Avatar
Car: 1986 IROC
Transmission: TH700r4
Last time I looked at my smog pass, it said my 86 IROC was 3600lbs there abouts. with some guy who looked like 120lbs max.
Old Jan 28, 2003 | 03:44 PM
Drakar's Avatar
I wouldn't trust your smog papers unless they weight the car, cause if that is true my car is 2900 pounds
but ... if it is DAMN!!
GM wanted 82 to be almost as light as the first gen, so around 3000-3100, I think they managed 3150 or so with a Z28.
As the years rolled on the cars got a little "bigger".
I would say 3400-3600 for 87+
and 3200-3500 for 82-86
Camaros with GFX only also
for reference my GTA was most likely 3600+
Old Jan 28, 2003 | 06:15 PM
Makaveli's Avatar
what do u think/know if that changed in 87+, not specifically 87, but in the later years i mean, of the fbody that added a few hundred pounds? id be interested to know...
Old Jan 28, 2003 | 06:41 PM
jms's Avatar
jms
Some friends of mine shipped their 1982 Z-28 (bought new and still own) to Hawaii (mid 80s) and back (in the early '90s) and they claim to know the exact weight of their car because they had to pay by the pound!
3240 pounds, to be exact.
PS, At, Cruise, tilt, etc.
When I work on it for them, it is noticably easier to push around in my shop than my '88 GTA.
jms
Old Jan 28, 2003 | 08:19 PM
Mark W. Winning's Avatar
My 1992 Bird, with a 355 and a six speed rang in at 3560lbs on Moroso's scale.
Old Jan 28, 2003 | 08:31 PM
Dolph88sc350TPI's Avatar
Car: 88 Camaro SC, 86 T/A, 92 Eclipse
I just checked my weight on a cat-scale. I weighted in at 3410.
Cat-scales read in 20pound increments. Does anyone know how accurate cat-scales are?
Old Jan 28, 2003 | 11:06 PM
ZZ405's Avatar
Car: 89 IROC
Engine: ZZ4
camaro weights
My 89 Iroc with air, t-tops, full power, sfc's, and a full tank of gas weighs 3390#. The car has aluminum cyinder heads. Places I have taken weight off since I last weighed the car(to lower et's): front and rear sway bar-28lbs, spare tire, jack, and wrench-41lbs, 1/4 tank of gas-75lbs. That should take off about .15 sec. or give me 1.5 mph in the quarter.
Old Feb 8, 2003 | 01:42 PM
poncho@home's Avatar
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
89 GTA Full load
mine weighs 3560 lbs with a full tank of gas. It's fully loaded so it's on the higher end of 3rd gens...camaro's should be lighter!
Old Feb 8, 2003 | 01:52 PM
MdFormula350's Avatar
i would think a rear sway bar would help more to be on, then to take off for weigh saving?
Old Apr 2, 2003 | 09:13 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
https://www.thirdgen.org/techbb2/sho...hreadid=170809
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
