Drum to disc swap questions and help.
Old Jan 26, 2003 | 10:28 AM
TheLG4Whore's Avatar
Car: '86 Trans Am
Transmission: TH700R-4
Axle/Gears: 10 bolt 3.73
I've got an '87 base model bird with drum brakes.
I work at a garage and my boss is letting me strip his '87 trans am.
I'm not sure if I'll be able to get the rear but if I get the disc brake assembly would anyone be able to tell me roughly what I have to do?
Do I need to weld up a bracket or do I have to cut or modify my rear differential?
I'll post a pic of my current setup later today.
Old Jan 26, 2003 | 10:47 AM
Parrydise7's Avatar
You might want to check out a post below yours entitled "PBR Rear Calipers." There is a lot of good information, but, at least for some members, this is a real emotional subject.
Old Jan 26, 2003 | 02:57 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I would not bother putting on iron caplier disc brakes. No one seems to like them, even when they work right. Either go with the 89-92 aluminum PBR setup (sometimes called the 1LE rear brakes) or with newer LS1 brakes. Heres a tech article. https://www.thirdgen.org/newdesign/t...reardisc.shtml
Old Jan 27, 2003 | 12:18 AM
Sitting Bull's Avatar
Car: 1986 Sport Coupé
Engine: 305-4v
Transmission: 700R4 and TransGo2
For your average driver who has hopped his Camaro up to run in the 13s or 14s, the drum brakes are fine, IMHO.
Mine stop me in short order, so I just don't even feel the urge to change over to disks
Scorched1984
Wheels and Tires
66
Apr 16, 2016 06:56 PM
gta90
Sep 15, 2015 04:00 PM
redmaroz
Aug 16, 2015 11:40 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
