installation of 96 rear disc on 86?
Old Jan 30, 2003 | 01:37 PM
jaymz's Avatar
Can I installa set of 96 ten bolt rear discs on a 86 9bolt rear disc BW? What backing plate can be used for this conversion? Thank You
Old Jan 31, 2003 | 06:35 AM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
You can but you will need the correct 9 bolt backing plates for those brakes, and new rotors. Contact AndyZ28 for them. You can go about it by doing other ways, but I recommend doing it "right".
Ed
Old Feb 1, 2003 | 12:42 PM
jaymz's Avatar
Do you think i will need any other parts to do this? I have the origional parking brake cables,calapers and roters from the 96 .Should I use a set of flex lines from the 96? What about hard lines? Will these brakes be the same,better or not as good as the PBR brakes?
Old Feb 4, 2003 | 08:05 AM
ebmiller88's Avatar
Since the 9 bolt was a disc rear, you can use those hard lines. I recommend getting new flex lines since they're cheap and why use old parts here? Then just use the '96 brake parts.
What year is your car? You may need to get a set of '89 disc brake e-brake cables since your car (depending on year) will have a different style brake adjuster than the '96 car and lines will.
These brakes ARE PBRs so they will be JUST as good...
The only problem I see you having is the e-brake stuff. Maybe you can find a guy who has done this swap and get more hints.
HTH...Ed
Old Feb 7, 2003 | 01:41 AM
jaymz's Avatar
Thanks for the info. I have a 86 IROC.
I am also from SC Greenwood.
Thanks again
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
sailtexas186548
Jan 19, 2016 12:21 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
1992 Trans Am
Aug 8, 2015 08:16 PM
