Polyurathane
Old Feb 2, 2003 | 07:52 PM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Polyurathane
Does this detoriate ride quality??
What are pros/cons?
Old Feb 3, 2003 | 01:24 AM
BretD 88GTA's Avatar
Car: Yes...
Engine: Last time I checked...
Transmission: See "Engine"...
Re: Polyurathane
What are pros/cons?
The pros:
Better handling
The cons:
Slightly more road noise and vibration transfered to the body. Personally, I doubt you'll notice it much.
The main question you need to ask yourself is "What do I want my car to do?"
If you want it to handle and perform better, then poly is the way to go. If you just want a cruiser, then stick with rubber bushings.
Old Feb 7, 2003 | 06:59 AM
MdFormula350's Avatar
in most locations poly is the way to go, it seems.
Old Feb 7, 2003 | 02:33 PM
Zerstörer's Avatar
Car: 1992
Engine: 350TPI
I have read where poly will cause alot of bind in the suspension and squeeek.
Old Feb 7, 2003 | 03:52 PM
Car: Yes...
If you keep poly bushings properly lubed, then they won't squeak.
As for suspension bind – Yes, since the poly bushings are much stiffer they will tend to cause bind in hard cornering situations. This is why some people, including myself, run a combination of poly bushings and heim joints.
Old Feb 7, 2003 | 06:13 PM
sllt1776's Avatar
Car: 89 Iroc-Z
i say poly. just a bit stiffer but better handling. it's worth doing.
91_5.7_TPI
Jan 29, 2009 12:24 AM
92RSMuscle
May 19, 2004 07:13 PM
stuart69427
Jan 1, 2002 08:49 PM
