36mm poly bushings
Old Feb 8, 2003 | 05:17 PM
alloy's Avatar
Car: 87 IROC-Z28
Engine: 305 TPI-New 355 on the engine stand
Axle/Gears: 3.73 Eaton posi-Soon a 9" Ford!
36mm poly bushings
Since search in down I can't look this up, but I seem to remember posts where it was stated that for 36mm sway bars they "honed" poly bushings to make them larger to fit a 36mm bar. I'm curious what type of tooling is used to hone a poly bushing to fit the 36mm bar?
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Re: 36mm poly bushings
Why don't you just get a 36mm bushing? They make them you know.
http://www.fbodymotorsports.com/inc/...l?v=1&pid=1866
Summit sells a 1 3/8 in. or 35mm set as well.
Old Feb 8, 2003 | 05:35 PM
alloy's Avatar
Car: 87 IROC-Z28
I know they make them, but I've already got 34mm poly bushings and I own a machine shop. For me it's hard to justify spending $35 plus shipping if I can take .078 out of these bushings for the 36mm bar. I'm thinking about using and end mill and writing a quick program for my machining center and trying to do it that way. But that's cutting, not honing. That's why I asked about what tooling is used for honing them.
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
