spring rate...yet again?
Old Feb 11, 2003 | 04:01 PM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
Transmission: th-400
Axle/Gears: 4th Gen 10 bolt/Detroit TrueTrac 4.
alright i want to buy some new springs but dont know what rate to get. i want a stiffer feel to my ride. it dipped and dived to much and with my low clearance issue with exhaust it doesnt help much. how stiff is too stiff? any reccomendations? thanks
Old Feb 11, 2003 | 04:14 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
well for springs alone you cant really have a "stiff" suspension. It can be more firm but springs alone wont really do it. Once you start putting poly bushings or rod ended parts then your rides gonna suck. haha...but really the only choice you really have is like eibachs, H&R, etc. Unless your gonna go with the ground control weight jack system. 800/175...I think I may upgrade the back to about 300 or more though cause 175 is way to soft.
Old Feb 11, 2003 | 04:18 PM
confucius101's Avatar
yea just through on the Energy Suspension hyperfelx kitt add a set of sfc's and you'll be really stiff
i'm starting to consider switching back to reg runner bushings
Old Feb 12, 2003 | 12:13 AM
spartyon's Avatar
Car: 1986 camaro
Engine: 383 sbc
thanx guys, so 800 up front? 2-250 on back? that sound good. i was gonna do the poly bushings and homemade sfc to clear my exhaust.
Old Feb 12, 2003 | 12:44 AM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
Most guys racing 3rd gens are running 225lb springs in the rear. smaller increments in the rear will produce big gains- just a caution not to jump up to high of a spring rate in the rear or things will get loose( The back end will come around ) on you.
LT1Formula
Oct 8, 2015 08:34 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
