Steve or anyone else. Q on 9" and relocating brackets
Car: 1991 Camaro Z28
On the site it says that there are relocation brackets for 10 bolt and 12bolt rear ends, and then a spot for moser 12 bolts and moser 9".
What about Currie 9"? Or is it assumed they are the same as moser?
Car: 87 IROC Z-28
Engine: 406-Mini Ram-AFR 195's-DFI Gen 6.32
Transmission: 700-R4 w/Art Carr converter
Axle/Gears: 9" - 31 spline - 3:89
On the Moser rear the LCA mounts are fabricated out of a thicker steel so if you measure the width of the mount it should be 2 7/8" and a 10 bolt is 2 3/4" if memory serves me correct. If you have a Moser 9" measure the width of the mount. I have a old Moser (1995) and the LCA mounts are the smaller because they were cut off of another rear and welded on but all of the more recent Moser 9" are fabed.
