I know this has been asked, but....
Old Mar 4, 2003 | 09:40 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
I have a different question to add in.
I have recently read that Eibach Pro-kit is only progressive in the rear. The front is linear. Is this true?
I want to cut ~1/2 a coil off of the front. Is this okay for comfort? I mean, I know it won't be stock, but it won't be like 800lbs/in from a progressive.
If I cut the front, what should I do with the rear? Should I use the prokit rear, or should I take the stock springs and cut them down?
TIA
Old Mar 4, 2003 | 02:13 PM
Kandied91z's Avatar
i cut 1/2 of the top coil on my fronts only and it worked great....i followed an article by gmhtp. the car that was used is a member here as well, although i have yet to see him on the boards.
it worked fine however i suggest changing your bumpstops as you will hit them and cause a bouncing effect. once that is cured the car works perfect but is slightly lower in the front.
good luck, remember don't cut the spring with a torch and you'll be fine.
F.I. 57 Belair
Aug 23, 2021 01:09 AM
LittleFranks
Oct 7, 2015 11:26 PM
89-91fun
South West Region
Sep 12, 2015 03:06 PM
89fast5oh
Sep 8, 2015 09:55 AM
Street Lethal
Sep 7, 2015 01:09 PM
