rear is leaning on pass. side
Old Mar 12, 2003 | 04:38 PM
panman79's Avatar
What would cause the rear passenger side to lean about an inch lower than the driver's side? I've already replaced the springs with new oem springs. There is an aftermarket panhard bar on the rear that came on the car when I got it. I'm putting new kyb gr2 gas shocks on it next week, and getting the front end aligned. I just hope it's not a twisted frame. Thanks for the help
Old Mar 13, 2003 | 11:57 PM
ebmiller88's Avatar
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
Lose the "hefty" chick...
Seriously, how many miles on the car? Any accidents? Your springs may be shot...due to the "hefty" chick.
LOL, Ed
Old Mar 14, 2003 | 08:25 AM
panman79's Avatar
There was a light accident on the front, I don't think it messed up the frame, it damaged the radiator support alittle and thats about it.
So if I put the hefty chick in the driver's seat for a few days, things will even out?
I changed the springs already, changing the shocks next week.My dad said he thinks it could be a broken shock mount. I doubt it but I'm running out of possibilities.
Old Mar 14, 2003 | 08:36 AM
Jekyll & Hyde's Avatar
Car: 1988 Camaro IROC-Z
Engine: 350 TPI (L98)
Axle/Gears: 9-bolt 3.45
Shock mounts are easy to check, look there first. Did you lower the car with the new springs? If so, did you get a pan-hard rod?
Old Mar 14, 2003 | 03:22 PM
panman79's Avatar
Did yall read my first post? I put factory hieght springs on the car.
The after market pan hard rod came on the car when I got it. Thinking about hitting a junkyard and getting a factory panhard rod just to see if thats the culprit.
Old Mar 14, 2003 | 06:38 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
well i'll buy the aftermarket one if you're getting rid of it...
Old Mar 15, 2003 | 01:39 AM
ebmiller88's Avatar
I seriously doubt the shocks would have any effect on ride hieght. All they do is dampen the bumps...the springs "set" the car on the ground. I'd check to make sure you have all of them seated properly in the buckets and perches. Maybe you don't have one of the fronts indexed right.
Ed
1992 Trans Am
May 10, 2023 07:19 PM
Street Lethal
Aug 14, 2015 08:25 PM
BlackBoulder
Aug 11, 2015 11:15 PM
novaderrik
Aug 10, 2015 12:44 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
