wonderbar + drag racing = ?
Old Mar 13, 2003 | 12:35 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Will i notice a difference if I put the wonderbar on a mostly drag suspensioned vehicle? Is there a strength related reason to put it on?
The car has sub frames and a cage.
Old Mar 13, 2003 | 01:12 PM
REVLIMIT's Avatar
Car: 1984 Chevy Camaro
Engine: Built L98
Transmission: T-56 6 speed
Hmmm...I'm kinda saying no...when I put on the wonderbar I didnt notice really any difference in launching or anything like that. I did notice a difference though when I was flying around a turn.
Old Mar 13, 2003 | 02:21 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
Yeah with solid end-linked swaybar, drag springs and Lakewood drag shock/struts...I am not going to be flying around any corners intentionally.
Old Mar 13, 2003 | 09:14 PM
LeftTurn1LE's Avatar
That's a good question. Some people remove the front sway bar for drag racing. I'm also wondering if the Wonder Bar has any effect.
Old Mar 13, 2003 | 10:18 PM
Momar's Avatar
I doubt it. The reason the swaybar has an effect is because it ties the suspension to the frame. When you disconnect it it allows the weight to transfer to the back of the car quicker and gives you better traction. It also gets rid of some weight but I dont think that is as big of an issue.
The wonderbar just attatches both sides of the frame to strenthen it. The only benifit of not having it would be the weight which isnt very much.
Ben
Old Mar 18, 2003 | 09:38 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
it won't make any diference...all it is is a strut tower brace at the bottom of the suspension/steering system instead of at the top. nothing at all to do with weught transfer, etc.
-Brian
Old Mar 18, 2003 | 12:43 PM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I was thinking more on the lines if the car pulls the wheels, the shock of one coming down before the other or stuff like that.
I guess not though.
BrianChevy
Wheels and Tires
Aug 8, 2019 02:16 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
gord327
Oct 3, 2015 01:25 PM
meeklay812
Oct 1, 2015 03:46 PM
JSDaddy189
Sep 26, 2015 03:50 PM
