Discount tire is crap
Old Mar 16, 2003 | 10:55 AM
Greg90iroc's Avatar
I was trying to do a complete brake job on the roc. I got the parts and every thing. One lug is completly round and the others well i broke a 1/2 inch rachet, 1/2 inch to 3/8 inch adapter and twisted a 1/2 inch extension off. I got one lug off. I have never seen lugs this tight and did not know an impact could produce this kind of torque. I had a 2 foot cheater bar on the rachet and i was bouncing my body weight (220 lbs) on it no luck. Any one know how to take off a rounded lug other than drilling it out? Should i just take the car to discount and tell them that they put the lugs on there and they have to get the lugs off?
Old Mar 16, 2003 | 11:04 AM
SuperchargedRS's Avatar
Car: Camaro of course
They probably put them on w/ a impact wrench, so I'd take them off w/ one if I were you. I would NOT take your car back there, I mean the F'ed it up once why go back again. So...just use a impact wrench, you can even get those electric ones that hook up to your bat. for emergincy use for like 40 bucks.
Old Mar 16, 2003 | 11:22 AM
Greg90iroc's Avatar
Tried that too. A freind has an impact didn't do any thing. i have always managed to break bolts loose with a cheater bar that impacts could not budge. Granted I do not have acess to the kind of impact wrenches the guys at the shops have.
Old Mar 16, 2003 | 04:00 PM
Marc 85Z28's Avatar
Most 1/2" impacts can't produce more than 500ft/lbs. How long is your breaker bar? You need something that is at least 24", or if that is not available, find a long pipe you could slide over your existing breaker. Either the lug nut will loosen, or the stud will break. Either way the lug will come off.
If I were you I'd go back to Discount Tire and ask the manager if his techs use torque sticks. If he can't prove to you that every tech has them and uses them, create a huge scene. It's embarassing, but being a technician myself I don't put up with that bull****. You'd be surprised what the manager will do for you...
Old Mar 16, 2003 | 07:30 PM
Greg90iroc's Avatar
I am going to discount tomarrow. i am going to make them get the lugs off. The torque tube is ok but i don't know if they used one. I think there might be a problem with The lug contact to the wheel. If there are burs on the lug it could create what i am experiencing. If that does not work i am going to try a little r134a on the wheel and lug. But if discount won't fix it you bet there is going to be a scene and the bbb will be contaced. what if i were to get a flat i would be sol.
Old Mar 16, 2003 | 07:44 PM
87IROC350's Avatar
Engine: 5.7
On the nut that is stripped find a junk socket (preferable 12 pt)and pound it on. Then use the breaker bar to remove.
Old Mar 17, 2003 | 12:53 PM
Greg90iroc's Avatar
Discount rounded off one more lug nut but they replaced it. they got the lugs broken loose.
LiquidBlue
Wheels and Tires
32
Dec 10, 2019 04:06 PM
jrdturbo
Mar 31, 2016 02:58 PM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
F-body-fan
Sep 17, 2015 12:16 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
