Relocation Bracket
Old Mar 21, 2003 | 09:51 AM
vwdave's Avatar
Relocation Bracket
What is the theory on how they work?
Old Mar 21, 2003 | 10:23 AM
Dewey316's Avatar
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
basicly it relocated the mounting point of the lower control arm, so that the rear tires are driving into the ground instead of them trying to lift up. the are especialy needed on lowered cars, when you lower the car the angle changed, so the relocation brackets help correct the change in the angle.
of course that is just brushing the surface on how it works, do a search , there is alot of good info on exactly what geomity is optimal for diffrent uses and why.
Old Mar 21, 2003 | 10:30 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
check the Spohn web site...they have a littel description on there about how they work.
And, like he said, if you do a search you will find more info..I remember doing some research on here not too long ago and finding some good info.
-Brian
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
jovibuilt
Exterior Parts Wanted
Oct 18, 2015 08:12 PM
loud91rs
Oct 5, 2015 10:05 PM
meeklay812
Oct 1, 2015 03:46 PM
armybyrd
Sep 26, 2015 03:37 PM
