Wheellies and the like
Old Mar 26, 2003 | 12:40 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
Just wondering, I know that you can get the front wheels up with good traction, and I was wondering what suspention mods that consisted of...? I have nearly 300hp, and I have the Hotchkis panhard rod and the LCA's. What else is recommended?\
Also, post some pics of your suspention setup, so I can make sure I did mine right!
Old Mar 26, 2003 | 01:41 PM
Timz2882's Avatar
Car: 05' GTO
Engine: 6.0L
Transmission: A4
a very high stall converter and big gears and a set of wrinkling sidewall slicks.
Old Mar 26, 2003 | 02:41 PM
ede's Avatar
ede
more power, more traction, less weight
Old Mar 26, 2003 | 03:58 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you can manage to get about 22,000 ft-lbs or so of torque to the ground you could probably do it.
Old Mar 29, 2003 | 05:09 PM
aaron7's Avatar
Car: 83 bird
Engine: 305/383
Transmission: WC T5
Axle/Gears: 3:42
New question: Can you do it with a standard? I never thought of that!
Old Mar 29, 2003 | 07:03 PM
brodyscamaro's Avatar
Car: 1999 Yamaha Banshee
Transmission: 6 spd manual
Axle/Gears: 14/41 tooth
I don't see why not, but with a T5 you might be looking at breaking it first.
Old Mar 29, 2003 | 11:02 PM
CaysE's Avatar
One trick I heard is upgrading the rear suspension only, leave the fronts stock. And remove the front sway bar (and wonderbar if you have one). If you're doing it with manual trans, either get the T-5 rebuilt with some hardcore parts or get a stronger trans. Same with the rear.
Old Mar 29, 2003 | 11:29 PM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
dont want to be a jerk but that would mean you would be pushing 1700 at the fly with that much you should be able to make it due a back flip if you want
Old Mar 30, 2003 | 02:21 AM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
Traction lift bars, giant rear tires (slicks), soft rear shocks, 90/10 front shocks, narrow front wheels ('skinnys', weight reduction), subframe connectors, high stall torque convertor, transbrake or roll control, soft front springs...
Thats all i can think of off the top of my head, and dont forget all the torque you'd need to do it. I'm sure there's plenty of other stuff though...
