Brake Booster delete . . . HELP!!!
I'm trying to remove the power brake booster and convert back to manual brakes (drag-only car and I need the engine compartment space for valve cover removal, spark plug access, etc).
Does anyone know if there is a different master cyl. that will bolt up in place of the booster or if anyone makes a bracket to delete the booster? I found a company called TRZ Race Cars, but they only make a unit for the 4th gen.
Any and all help would be appreciated!
Thanks!!
Don
Thanks!!
Don
Car: 93 240SX
Engine: LQ9
Axle/Gears: 3.54 R200 IRS
So use their bolt in 4th gen booster, and manual if they have it, i know the 4th gen booster will bolt in just the same to the firewall as a 3rd gen, not sure if a 3rd gen master will bolt to the 4th gen booster, im going to use both from a 4th gen.
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
Night rider327
Sep 2, 2015 04:17 AM
