Rear disk brake set-up
Old Apr 1, 2003 | 06:47 PM
Dave Y's Avatar
Car: 04 Xtreme Blazer
Engine: 4.3L V6
If HITHERE get these parts from
http://www.thirdgenresource.com/
will this be all HITHERE Need to install rear disk brakes on my 89 IROC w/ 10 bolt rear end?
L & R Calipers 89-92 , used $ 35 each
2 rotors 89-92 , used $ 20 each
L & R caliper mounting brakets 89-92 , new $ 18 each
1 rear disk brakeproportioning valve 89-92 , used $ 50
2 HITHERE-brake cables 89-92 , new $ 39 each
New pads
hoses& other misc. hardware (bolts, ect.)
is this what HITHERE will need?, anything else that HITHERE missed?
Old Apr 4, 2003 | 08:13 AM
ANDYZ28's Avatar
Car: 1982 Z-28
Engine: 5.0 w/ Holly carb
Transmission: TH-700R4
Are these conversion components to be installed on a drum, or disc rear.
What brake lines and hoses are you going to use?
Thanx, andyZ28
Old Apr 4, 2003 | 11:08 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Hey, AndyZ,
Welcome back to the boards. Should you still have a rear disc set-up, I'd be interested (I'd like to go from the old style rear discs to the PBR on my 85 IROC. I've modified my front spindles according to your instructions and will be ordering the 1LE brake kit from Steve within a few days). Be cool to do the whole business in one shot.
JamesC
Old Apr 4, 2003 | 06:34 PM
Dave Y's Avatar
Engine: 4.3L V6
I was wondering if these would work on a drum(10 bolt) rear
I would use whatever lines/ hoses I would need
Old Apr 4, 2003 | 09:09 PM
ANDYZ28's Avatar
Car: 1982 Z-28
Dave Y I suggest you get my CD if you are planning any brake upgrade using GM parts. James C and many other members have my CD, and you can ask their opinion abaut this.
Thanx, andyZ28
Vintageracer
Jan 10, 2020 05:33 PM
SpaniardV6
Brakes
19
Sep 7, 2015 03:04 AM
cam-mike
Aug 24, 2015 07:23 AM
