Hmm...rear suspension question/problem
Old Apr 12, 2003 | 12:12 AM
iggy1991's Avatar
Car: Red 91 RS Camaro
Engine: LO3 with Comp Cam
Axle/Gears: 4th gen rear
I just installed lowering springs, new KYB shocks, and an adjustable panhard bar on the rear of my 91 RS. Now the rear of the car gives off this clanking noice when I go over bumps at lower speeds. Any ideas what it moght be. I think it is the lowering springs making the noice since the rear end doesn't keep constant pressure on them like the old springs had so they might be moving around or something. ?????
Old Apr 14, 2003 | 11:21 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
did you put the rubber isolator back in with the new springs?
Old Apr 15, 2003 | 03:25 PM
iggy1991's Avatar
Yeah I did but they could have fallen out since the rear springs are not as tightly held in as the old one because they are shorter. Is that possible?
Old Apr 15, 2003 | 04:19 PM
mrr23's Avatar
Engine: 360 HSR
possibly. but doubt it unless you did not tape them to the springs. i put some suspension techniques springs in an 84 ta w/o them. made lots of noise. put new ones in and made it all better.
Old Apr 15, 2003 | 06:00 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Have you re-checked all those suspension bolts to make sure they're still at the proper torque spec?
Also, check out your exhaust's intermediate pipe (catalytic convertor to muffer), make sure it's not getting bent up by the shorter clearance in the "V" between the panhard rod and track bar brace.
LT1Formula
Oct 8, 2015 08:34 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
