shocks and struts
Old Apr 16, 2003 | 10:54 AM
mjamerson3's Avatar
shocks and struts
Have a 89 firebird and had the shocks and struts replaced. Can't tell no difference. Every little bump I hit It feels as if I'm ridding in a wagon. What would be the best to get for a smooth ride so when that when I do hits small bumps and not rattled to pieces? Thanks
Old Apr 16, 2003 | 12:59 PM
92GTA's Avatar
Buy and Cadillac and don't drive through pot holes
Seriously though, these cars weren't designed for grandma drivers, good handling is a trade of for a rough ride on bad roads...
What kind of shocks and struts did you use?
Old Apr 16, 2003 | 01:04 PM
swerve-driver's Avatar
From: "When the going gets weird, the weird turn pro." -RIPHST
Car: 1991 RS
Engine: 383TBI Fastburns and 2"TB
Transmission: T56 held up by Spohnstuff
Is your car lowered? Do you have the stock aspect ratio tires on it?
If it is lowered with "rubber-band" tires on it, it will ride rougher.
I lowered mine and put 245 45 17s on my car and the ride is much rougher, but I was going for response and that is exactly what I got.
I also replaced all bushings on the car at the same time.
Did you replace your bushings? If you replaced them with higher performance ones, the ride is a little rougher.
S-D
Old Apr 16, 2003 | 03:54 PM
Jon92TA's Avatar
Car: 92 Trans Am - Sold
The Monroe's I got are pretty smooth, not what I'd consider a performance strut/shock. I'm thinkin the fronts are probably softer than factory units, rears are ok.
Old Apr 17, 2003 | 09:23 AM
mjamerson3's Avatar
They put McPherson struts on the front and Gabriel shocks on the back and put new wheel bearings on the front
Ed1LE
Sep 30, 2018 09:14 AM
LT1Formula
Oct 8, 2015 08:34 PM
loud91rs
Oct 5, 2015 10:05 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
meeklay812
Oct 1, 2015 03:46 PM
