Can somebody please tell me what car(s) will have a direct bolt in master cylinder for our brakes. Thank you.
Take an S10 manual master cylinder and the pushrod assembly. You take and cut down the pushrod and thread one end for a rod end. take the brake pedal out and drill a hole 1" higher than the factory pick point. bolt the rod end through there and adjust till you get good pressure on the brakes. Re route your lines and you are done.
Cheers,
Cheers,
