Are adjustable rear shocks worth it??
I'm looking to improve weight transfer and traction on my Camaro. I've already got Spohn subframe connectors, lower control arms, lca relocation brackets, and an adjustable torque arm. Would getting a set of adjustable rear shocks help with my launch? I would think that getting them and setting them on the softest setting would, but I'm not sure. I don't have the money for the struts yet. What brand should I go with if this is worth it? Thanks in advance.
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Softer shocks in the back will make better weight transfer. I think HAL makes a good adjustable one.
86-TC-2501-P HAL Adjustable Rear Shock, 1982-2002 F-body (each)
$139.99
http://www.thunderracing.com/index.c...ategoryid=1071
they seem to have a wide vareity of setting for street ot track use.
i think i am going with them.
$139.99
Car: 1986 Camaro Z-28
Engine: Chevy ZZ4
Transmission: Select Built 700R4
Axle/Gears: Moser Axles / 3.73 Richmond Gears
I have Competition Engineering #C2700 rear Drag Shocks. They're three way adjustable, 50/50, 40/60, or 30/70. They're only $39.95 each through Summit. I bought them locally for slightly less and they seem to work well.
LT1Formula
Nov 16, 2015 01:13 PM
1992 Trans Am
Aug 9, 2015 04:32 PM
3070, 4060, 5050, 86, adjustable, camaro, competition, drag, engineering, fbody, rear, shock, shocks, torque, worth
