Poly Bushings
Old Apr 29, 2003 | 01:57 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
Poly Bushings
I need pushing all around... Tranny mount, torque arm, front and rear swaybar. I have heard that the poly bushing are too hard and cause a lot of sweaks and rattles. Anyone had problems with them. Should I just get the rubber bushings?
Old Apr 29, 2003 | 09:20 PM
chevymad's Avatar
Car: 87 Formula
Engine: 327
I've got all poly now, and like em. The only thing that made alot more noise/vibration then before was the poly tranny mount.. Lowering the crossmember with some washers helped a bunch. I may need to go further yet.
Old Apr 30, 2003 | 01:27 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
No problems.
JamesC
Old Apr 30, 2003 | 01:42 PM
Schultzy89GTA's Avatar
Car: 1989 GTA
Engine: 383 Miniram AFR195
Transmission: Tremec TKO
Axle/Gears: BW 9 Bolt/3.70
It does stiffen things up so there may be a bit more noise associated. But hey, you are driving a thirdgen so what's another squeek or rattle!
IMHO, the performance gain more than offsets any minor increase in noise.
-Schultzy
Old Apr 30, 2003 | 03:04 PM
CaysE's Avatar
I love em. the noise increase from the tranny mount was barely noticeable, and I put plenty of grease on the sway bar mounts, so they don't squeak at all. I have yet to put the engine mounts in, which I think will cause the most noise increase.
Old May 2, 2003 | 02:19 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I didn't notice any noise from the ES poly Engine Mounts, and I drive with my windows down alot, and that was before I had loud exhaust.
Just my HO.
Old May 2, 2003 | 02:30 PM
JamesC's Avatar
Note the sig. No noise.
JamesC
Ed1LE
Sep 30, 2018 09:14 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Nervous2
Oct 8, 2015 10:53 PM
loud91rs
Oct 5, 2015 10:05 PM
mfp189
Sep 27, 2015 09:25 AM
