So the suspension is 18 yrs old...
Old Apr 30, 2003 | 09:43 PM
BackInBlackGP's Avatar
Car: 1986 W69 Special Edition
Engine: 2.8/ECM/Int/Exh
Axle/Gears: 3.42 posi
Can anyone recommend me an inexpensive full suspension bushing kit to re-hab my Bird? The stock rubber has held up this long, but it's starting to feel a little loose over bumps and through the corners. Since I don't drive it a whole lot, I don't think I need a poly set... Thanks for the suggestions!
Old Apr 30, 2003 | 10:18 PM
nikh23's Avatar
Car: 88 IROC Convertible
Transmission: Raptor 700
check out this thread
https://www.thirdgen.org/techbb2/sho...hreadid=176378
Old Apr 30, 2003 | 11:04 PM
mike1986fyrbird's Avatar
Car: 1987 Trans Am GTA
Engine: 357ci Stealth Ram - Under Pressure
Transmission: Built 700r4/Pro Yank 3400 Extreme
Axle/Gears: 9-Bolt 3.27
Re: So the suspension is 18 yrs old...
You mean 16 right?
Old May 1, 2003 | 01:32 AM
nikh23's Avatar
or 17 since its a 1986. 1986 + 17 = 2003 heh
Old May 1, 2003 | 05:55 AM
Well, the car was build middle of 1985... Closer to 18 I guess...
LT1Formula
Oct 8, 2015 08:34 PM
z28joe2
Sep 28, 2015 05:54 PM
