best suspension dealer?
Car: 87 vert
This would be two part question. First off I want to re-do my suspension(ie. strut tower brace, torque arm, panhard, LCA, LCA brackets, and 1" drop springs). Would boxing in my LCA's and panhard be better or getting aftermarket? Which company would give the better "deal" on this type of complete package?
First off, do you have a V6 or V8?
Makes a differance on what type of springs you want.
You could "box in" your existing stock ones, but would
have to remove them from the vehicle, buy some quality
steel ( mild steel pieces will do) , have them cut to fit,
then welded to the LCAs, then replace the old, worn
out rubber bushings with polyurethane, or polygrahite,
your choice ( polyurethane is easier to find), make sure
to buy greasable ones, then sand, prime, and paint to
whatever color you want, then finally install them in
you car. I'd rather spend the extra dough and buy
already better made ones from Spohn, save some
time too!
I'd go with Spohn for EVERYTHING!
Get ALL of your suspension stuff through them.
They make everything specifically for our cars.
Most of my suspension parts I bought through them.
I would have got everything, but they did not have any
steering braces ( wonder bars) or any SFCs ( subframe
connectors) available at the time.
I'd go with all adjustable parts too, especially of you
plan on lowering your car. But it's up to you.
I've shopped around quite a bit for suspension parts
found that Spohn not only offers better quality parts,
but most of them are cheaper!
Heres' the link ( also on top of this website!)....
http://www.Spohn.net
time too!
Car: 87 vert
thanks for the response. I just swapped in the LT1(had a 305 - my sig had my mod info... wondering what happened?).
Can't recall right now, but didn't the iroc's come with the factory wonder bar?
I'm going to Spohn route. I'm going to call in my order and see what deals they can give me since I'm going to do it all at once.
Going to do the sway bar bushings as well.
Car: 1990 Camaro RS
Engine: Juiced 5.0 TBI - 300rwhp
Axle/Gears: 3.42 Eaton Posi, 10 Bolt
if you are lowering, make sure you get an adj. Panhard. so you can recenter your **** end.
Yeah, my sig disappeared too. I have to fix that.
Anyways, I believe that the IROCs did come with the
wonder bars. I think they were only made for a few years
though. Like 1985-1990. That's just a guess.
I never owned an IROC or Z28, unfortunately, I only
have and will own an RS.
LT1Formula
Oct 8, 2015 08:34 PM
