Where to install the Line Lock?
Old May 4, 2003 | 10:42 PM
mdricken's Avatar
Car: 92 Camaro
Engine: ZZ4 Crate Engine w/Hot Cam
Transmission: Rebuilt 700R4 with Transgo and MW 3
Axle/Gears: 3.73 Eaton Posi
I purchased a line lock solenoid on ebay and I am told that you put it in line with the front brake lines to hold the pressure in those lines while you let go of the pedal and do a burnout.
BUT - When i looked in my car there is a brake line going to each front wheel (2 lines from the resorvoir/diverter), so do I need two solenoids or what?? Is a tee the way to go??
Anybody ever done this before??? Please help..
Thanks!!
Old May 4, 2003 | 11:03 PM
89IRO's Avatar
Help the man! I would like to know too!
Old May 5, 2003 | 03:47 PM
ede's Avatar
ede
you need a tee, i'd guess you can find instructions on line from the makers web site.
Old May 5, 2003 | 03:50 PM
CaysE's Avatar
i agree. give the company a call, even.
Old May 9, 2003 | 03:32 PM
IHI's Avatar
IHI
Car: 86 firebird with 98 firebird interi
Engine: pump gas 427sbc Dart Lil M 13.5:1
Transmission: Oldani TH400 w/ BTE 9" convertor
Axle/Gears: 31 spline Moser/full spool/4.11Rich
For the front line lock yes you do need a tee as that'll tie the front lines together on the sides and then the line lock will plug into the top, if running a rear line lock it just gets plumbed in-line. I mounted both my line locks on the drivers front fender near the MC, you'll either have to get adapters-if they have them in your area- or cut off the metric ends and install standard flare fittings on the brake lines them selves like I had to since the car has the bubble flares and the line lock will have standard. Pretty easy to do.
Old May 10, 2003 | 09:34 AM
mdricken's Avatar
Car: 92 Camaro
Thanks for the info. I finally found the PDF instructions for the Hurst unit. It's under the Mr. Gasket website, if anybody wants to know.
Oh by the way - I learned an important lesson yesterday - Don't do burnouts on gravel unless you plan on completely destroying your tires!!!! Gravel is much more vicious on your tires than pavement - But it did seem to make more smoke....
Thanks again
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
I'llrocya
Feb 2, 2016 11:43 PM
