rs vs. z28 suspension
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
Axle/Gears: 4.30 Dana 44 Rear 10 bolt front
today, since i was bored i was looking up rpo codes on both cars, and found that the rs had an f41 firm ride and handling code. was this the case on all the rs cars, b/c the z28 had the f41 code as i expected it to.
the rs and z had the same rear spring rpo codes, but different front spring codes. are the sway bars the same? b/c if they are different, i'm going to get the same bars for the rs,
the z really didn't have any perf. options added on, so what are the absolute basic upgrades that a plain-jane z28 has over the rs besides posi, and tpi engine? like are the brakes any better, etc.?
thanks for any help
mike
thanks for any help
mike
The rs with 16 inch wheels and z suspension are esentially the same with the exception of the front springs. I believe they also have the same sway bars. The only difference between the rs brakes and the z 28 brakes without g92 is the z28 has aluminum drums compared to the rs' iron drums. Hope that helps.
Car: '88 Iroc, '91 RS, and a '70 RS
Engine: 5.7 TPI; 5.0 TBI; ZZ4/T56 on the ag
Transmission: A4, A4, slated to be a T56
I have an '88 Iroc and a '91 RS.
The Iroc came stock with BZW/NNL springs, 34mm hollow front and 24mm rear swaybars. It came with the J65 disc/disc brakes.
My RS has the F41 package but all RSs didn't get this code. It has the same springs, BZW/NNL, and did come with the 34mm hollow front bar, but got a 21mm rear bar. As stated, it came with the bigger wheels and tires, the crappy 2.73 open rear, and drum brakes out back. I know you guys say the front springs are different, but the tag's still on the coils.
Ed
Ed
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
the z28 doesn't have aluminum drums, its a 2.73 posi.
the rs is a 3.08 open.
i just checked it with a magnet, and it didn't have a code on the rpo sheet for it, this car was basically the lowest level perf. z28, no accessories but t-tops and pow win./locks
so which sway bars would be diff. front or rear, my guess would be the fronts different, but who knows.
im considering parting out the z, so i need to know which parts i can use, that are worth it, if anybody wants parts, let me know, and i'll tell you what i got.
Car: '02 Rodeo
Engine: 3.2 V6 DOHC
Transmission: 5spd
my spring codes are as follows:
z28 rs
fr. 6XT 7XT 6XU 7XU
rr. 8NL 9NL 8NL 9NL
if anyone can shed some light on this, thank you
z28 rs
fr. 6XT 7XT 6XU 7XU
rr. 8NL 9NL 8NL 9NL
1Aauto
Sponsored Vendors
Sep 13, 2017 12:58 PM
Buggy Disaster
Sep 22, 2015 01:15 PM
84 TA NV
Sep 6, 2015 08:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
