V6 sway bar sizes
Old May 8, 2003 | 04:14 PM
86camarodriver's Avatar
V6 sway bar sizes
Anyone know the stock sway bar sizes for the 2.8 v6 cars???
Old May 8, 2003 | 07:16 PM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
V6 swaybars
I removed 30mm/19mm from my 92 V6.
Old May 8, 2003 | 11:20 PM
AGood2.8's Avatar
Car: '87 Chev
Engine: 60*V6
Transmission: DY T700
'87 Camaro RS (Calif edition) Stock bars were 32mm hollow front, 23mm solid rear.
Old May 9, 2003 | 11:26 AM
82camaro's Avatar
Car: 82 camaro SC
Depends on the suspension package and the year. Mine had a small(about 7/8)front bar and NO rear bar from the factory.
Old May 9, 2003 | 11:47 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
My '86 has a 34mm front bar. Can't remember what the rear bar is.
Just take an open-ended adjustable wrench, and tighten it down on the center of the front or the rear bar. Loosen it SLIGHTLY so you can slide the wrench off, and measure the gap of the wrench with a ruler.
Remember not to start measuring with the end of the ruler- rulers aren't too accurate on their ends- the ends usually get damaged or worn down. Start measuring at the 1 cm mark.
J-money
Jan 4, 2019 09:45 AM
camaro1185
Oct 26, 2015 06:51 AM
m00n420
Sep 11, 2015 02:39 PM
87camaro87
Sep 9, 2015 10:29 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
