Rear suspension VS Radials = Damage
Old May 18, 2003 | 12:20 AM
Dan88IrocZ's Avatar
From idle, if I floor it, my tires hook and I hear a loud thunk. It's coming from the right rear of the car. I've visually inspected just quickly and didn't see anything wrong with my LCA & sway bar rod end.
Also, it wouldn't be a tranny or motor mount, I'd feel that in my shifter.
It only makes the loud thump when I floor it from a stop or if I bounce my car real hard in first gear. Big bumps don't make it thunk either.
Any ideas? Tomorrow morning I'll get her up in the air and start looking.
Old May 18, 2003 | 01:30 PM
MdFormula350's Avatar
well i would suspect wheel hopping, casued from maybe bad bushings in the lca's, possible lose rear shock or it being blown.
Old May 18, 2003 | 02:57 PM
Dan88IrocZ's Avatar
No wheel hop, LCA bushings are good and new.
My car hooks like a mother f'er, it actually hooks better now with whatever broke lol.
I'm waiting for it to cool down a bit so I can crawl under and find out what I broke.
Old May 18, 2003 | 04:18 PM
fisherbody86's Avatar
Car: 92 Z28 heritage
Engine: 5.0 TPI
I would check the torqure arm mount at the trans, the top bolt could have come loose allowing the torque arm to slam up against the floor.
Old May 18, 2003 | 04:56 PM
Dan88IrocZ's Avatar
Damn! I just dropped her off the jacks about 10 minutes ago and cleaned my driveway lol.
Looks like I'll have to do that tomorrow morning.
Now that I've listened to the sound more, it sounds more like something is hitting the floor. My GF said she feels the thump under her.
Old May 18, 2003 | 05:20 PM
Frik92RS's Avatar
Car: Camaro RS
Engine: L03 305
Transmission: 700R4 Auto
Check the driveshaft for freeplay in the U-Joints. If that's solid then check out the torque arm mount and trans mount. I'd also say while you're under the car to give everything a good once over to make sure everything is where it belongs and still bolted together.
Vintageracer
Jan 10, 2020 05:33 PM
bjpotter
Jan 22, 2019 12:27 PM
cam-mike
Aug 24, 2015 07:23 AM
