17 Weld Wheels
Old May 20, 2003 | 01:41 PM
SprayedGTA's Avatar
17 Weld Wheels
I have an 88 GTA, and my girlfriend is buying me some 17" Weld Drag Stars, or Drag Pros XP Series.(whatever they are called, not the Drag Lites though) I need to know if anyone has used these wheels, or if there is a wheel expert out there, what backspacing do I need so that none of the tire is sticking out. I want a pretty wide tire too, at least 10.5" wide, would prefer 11-12" wide. Please let me know. The motor is out, so I can't exactly get the car up to the shop for them to measure it. Any suggestions? And do I need spacers, I would prefer to not use them.
Old May 21, 2003 | 06:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
You got one hell of a girlfriend
Old May 21, 2003 | 11:11 PM
Kandied91z's Avatar
you will have a fun time trying to fit that under the rear inner fender....
just match up the backspacing with what is stock and go from there. what are you plans for the front?
Old May 22, 2003 | 02:27 PM
SprayedGTA's Avatar
It's my birthday and she makes really good money. If I go with stock backspacing, there is no way I can even get close to a 11 inch tire, unless I want to look like a vato in a 86 cutlass with 13" daytons. Sorry, not really wanting that look. The plans for the front are going to be somewhere between 7"-8.5" I don't want skinnies
Old Oct 13, 2003 | 07:21 PM
86IROCNJ's Avatar
Car: 86 Iroc-Z28
Engine: FB385
Did you ever go through with this? If so what size wheels/backspacing and tires did you go with? thanks
Old Oct 13, 2003 | 11:33 PM
prockbp's Avatar
Car: 1989 IROC-Z
Engine: 1992 TPI 350
Transmission: 1989 T5
Axle/Gears: 1992 10 Bolt Rear w/ 3.42 gearing
i use 16x10.5 CCW's for autocross......
in the front, the maximum backspace you can have w/out using a spacer is 5".. and you still might have to do some grinding/smashing here and there(i run 5.5"backspace wheels with a 1/2" spacer in front)
in the back.. my wheels have 5.5" backspace... and there's still a little room(they fit easily, no mods)... you could probably get away with 6" backspacing in the rear as long as you massage the inner fenders and don't go around turns very fast.... oh yah, you'll need an aftermarket panhard bar to keep the tires from rubbing the fenders(an adjustable one with rod ends is best)
Old Oct 14, 2003 | 12:19 AM
Kandied91z's Avatar
5.5 seems to be the norm in the rear....what was the stock rear spec again, anyone remember?
Lanz06
Sep 14, 2015 07:16 PM
Nick McCardle
Sep 10, 2015 08:36 PM
84 TA NV
Sep 6, 2015 08:02 PM
WickedBowtie
Exterior Parts Wanted
Sep 5, 2015 04:58 PM
