No wheel hop....no traction either!
Old May 25, 2003 | 03:08 AM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Transmission: Probuilt 700r4
Well, even since i have lowered my car I have not have wheel hop. But the thing is, the tires don't want to bite either. My e.t.'s are 2-3 tenths quicker when I really launch the car and let the tires spin, then they catch at about 4500 rpm and I shift at 5500. If I ease the clutch out, it's slower, but the tires aren't spinning.
What to do? I know you guys will say LCA relocation brackets and LCA's but is that really gonna plant the tires that much harder? I mean I'd like some #'s here. LCA's, brackets, and the labor to weld the brackets in will bring me to at least 150 bucks. I want' to know if it will be worth it, in tenths.
Is there anyone out there who ran mid 14's and then installed these parts? What was the e.t. reduction?
I almost think some drag radials will be more worth it but apparently they cost more and don't last as long as radials.
Old May 25, 2003 | 12:14 PM
mrr23's Avatar
Car: 1986 pontiac TA
Engine: 360 HSR
Transmission: 700r4 3300 yank converter
Axle/Gears: 3.27 9 bolt
i have the lakewood trailing arms and adjustable panhard rod. on motor i have done a 1.83 60ft on the n2o i've done a 1.76 60ft. this on 225/60-15 nitto touring tires. not drag radials. regular tires. i do not have the relocation brackets.
Old May 25, 2003 | 09:47 PM
330hp_91RS's Avatar
Car: 91' RS
Engine: Built 355
Nice.
I have the pabhard rod already, so maybe I can start with the LCA's and if they don't work maybe some brackets.
What is the motor/trans/rear setup in your car? Also: is it lowered at all?
Old May 26, 2003 | 12:50 AM
Dan88IrocZ's Avatar
Dude, really invest in a set of LCA's..alone should plant them well and you can save your money on going all out with suspension parts.
Old May 26, 2003 | 09:01 AM
mrr23's Avatar
Engine: 360 HSR
5.7 TPI 2100 converter, 3.27 , not lowered. but my friend has cut 1.8 with his lowered car and he has the lakewood trailing arms.
here's all my stuff www.fl-thirdgen.org/mrr23
here's his www.camaroworld.com/nitromethane
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
Numbah-1
Sep 12, 2015 08:57 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
dbrochard
Sep 7, 2015 09:41 AM
